[OpenLayers-Users] different coords format
    Bart van den Eijnden (OSGIS)
    bartvde at osgis.nl
    Mon Dec 10 07:19:26 EST 2007
You can use the function getLonLatFromViewPortPx on the map object.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
Naar: users at openlayers.org <users at openlayers.org>
Onderwerp: [OpenLayers-Users]  different coords format
Datum: 10/12/07 10:16
> hi,
> I´m trying to change the GetFeatureInfo request a little bit (to display a
> ka-map layer query) but have some trouble with the coordinate.
> I´m using basically this source code:
> var request =  window[id].getFullRequestString({
>                             REQUEST: "GetFeatureInfo",
>                             EXCEPTIONS:
"application/vnd.ogc.se_xml",
>                             BBOX: window[id].map.getExtent().toBBOX(),
>                             X: e.xy.x,
>                             Y: e.xy.y,
>                             INFO_FORMAT: 'text/html',
>                             QUERY_LAYERS: window[id].params.LAYERS,
>                             WIDTH: window[id].map.size.w,
>                             HEIGHT: window[id].map.size.h});
> now the problem is, the information I get for X and Y is e.g.:
>    &X=314&Y=319
> what I need is to change the coords to ka-map confirm coordinates in that
> format:
> &coords=474133.0773014716,181821.5684830197
> I hope someone have an idea how i change the e.xy.x and the e.xy.y to geht
> the coords format I need.
http://www.nabble.com/different-coords-format-tp14251884p14251884.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
