[OpenLayers-Users] different coords format
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Mon Dec 10 07:48:27 EST 2007
tried with
coords: map.getLonLatFromViewPortPx(e.xy),
but that was not correct... how do I have to put the getLonLat... into this?
Bart van den Eijnden (OSGIS)-2 wrote:
> You can use the function getLonLatFromViewPortPx on the map object.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
> Naar: users at openlayers.org <users at openlayers.org>
> Onderwerp: [OpenLayers-Users] different coords format
> Datum: 10/12/07 10:16
>> hi,
>> I´m trying to change the GetFeatureInfo request a little bit (to display
>> a
>> ka-map layer query) but have some trouble with the coordinate.
>> I´m using basically this source code:
>> var request = window[id].getFullRequestString({
>> REQUEST: "GetFeatureInfo",
>> EXCEPTIONS:
> "application/vnd.ogc.se_xml",
>> BBOX: window[id].map.getExtent().toBBOX(),
>> X: e.xy.x,
>> Y: e.xy.y,
>> INFO_FORMAT: 'text/html',
>> QUERY_LAYERS: window[id].params.LAYERS,
>> WIDTH: window[id].map.size.w,
>> HEIGHT: window[id].map.size.h});
>> now the problem is, the information I get for X and Y is e.g.:
>> &X=314&Y=319
>> what I need is to change the coords to ka-map confirm coordinates in that
>> format:
>> &coords=474133.0773014716,181821.5684830197
>> I hope someone have an idea how i change the e.xy.x and the e.xy.y to
>> geht
>> the coords format I need.
>> View this message in context:
> http://www.nabble.com/different-coords-format-tp14251884p14251884.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14252088.html
