[OpenLayers-Users] different coords format
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Dec 10 07:59:01 EST 2007
Hi Chris,
thanks for the clarification, so why is it labeled as an API Method if it is
meant to be internal?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Christopher Schmidt <crschmidt at metacarta.com>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>, users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] different coords format
Datum: 10/12/07 10:56
> On Mon, Dec 10, 2007 at 01:19:26PM +0100, Bart van den Eijnden (OSGIS)
wrote:
> > You can use the function getLonLatFromViewPortPx on the map object.
> actually, getLonLatFromPixel is the right function to use here:
> "FromViewPortPx" is a more internal function that we wrap up
with
> getLatLonFromPixel.
> Regards,
> Christopher Schmidt
> MetaCarta
