[OpenLayers-Users] Feature.Vector.atPoint ?
Pierre GIRAUD
bluecarto at gmail.com
Mon Dec 10 07:42:10 EST 2007
You're right, the atPoint method intended behavior is to check whether
a point in contained into a geometry bounding box. This was
implemented a while ago as an simple way to simulate event handling in
some cases, though it's far away from being perfect.
About 2 months ago, Tim Schaub proposed a real intersection method
support [1]. It's still in progress and help on this would be much
appreciated.
Regards,
Pierre
[1] http://trac.openlayers.org/ticket/1072
On Dec 10, 2007 1:34 PM, Attila Csipa <plists at prometheus.org.yu> wrote:
> I have a question about this method, the description says "Determins whether
> the feature intersects with the specified location.", however in my
> experience this returns true if the given point is in the feature's _bounding
> box_, not the feature itself. Is this the intended behaviour (a bit of
> clarification of the description would help in that case), or is this
> a 'todo' style item for which bbox matching is a quick hack ? I'm using the
> latest svn release of openlayers. Sorry if this has come up earlier, I joined
> the list fairly recently and found no reference to this on issue on google.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
