[OpenLayers-Users] different coords format
Pierre GIRAUD
bluecarto at gmail.com
Mon Dec 10 08:12:35 EST 2007
You should have something better using :
var coords = window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y);
Then you can access coords.x and corrds.y.
Regards
On Dec 10, 2007 2:05 PM, Ortner Reinhard
<Reinhard.Ortner at edu.fh-kaernten.ac.at> wrote:
> thx, but back to my question :)
> can i use it like:
> coords: getLonLatFromPixel(e.xy.x, e.xy.y)
> because it doesn´t work like that
> ________________________________
> Von: users-bounces at openlayers.org im Auftrag von Bart van den Eijnden (OSGIS)
> Gesendet: Mo 10.12.2007 13:59
> An: Christopher Schmidt
> Cc: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] different coords format
> Hi Chris,
> thanks for the clarification, so why is it labeled as an API Method if it is
> meant to be internal?
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl <http://www.osgis.nl/>
> --------- Oorspronkelijk bericht --------
> Van: Christopher Schmidt <crschmidt at metacarta.com>
> Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
> Cc: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>, users at openlayers.org
> Onderwerp: Re: [OpenLayers-Users] different coords format
> Datum: 10/12/07 10:56
> > On Mon, Dec 10, 2007 at 01:19:26PM +0100, Bart van den Eijnden (OSGIS)
> wrote:
> > > You can use the function getLonLatFromViewPortPx on the map object.
> > actually, getLonLatFromPixel is the right function to use here:
> > "FromViewPortPx" is a more internal function that we wrap up
> with
> > getLatLonFromPixel.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
