[OpenLayers-Users] different coords format
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Mon Dec 10 08:37:24 EST 2007
Here´s my request:
var request = window[id].getFullRequestString({
q_type: "0",
extent: window[id].map.getExtent().toBBOX(),
coords:
window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y),
"http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation");
the problem is still the coords, here´s the actuall request:
http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation&g=Abflussstation&i=png&transparent=true&q_type=0&extent=385077.280363%2C131098.74813%2C600412.719637%2C227054.25187&coords=lon%3DNaN%2Clat%3DNaN
still something wrong with the coords, any idea?
Pierre GIRAUD wrote:
> You should have something better using :
> var coords = window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y);
> Then you can access coords.x and corrds.y.
> Regards
> On Dec 10, 2007 2:05 PM, Ortner Reinhard
> <Reinhard.Ortner at edu.fh-kaernten.ac.at> wrote:
>> thx, but back to my question :)
>> can i use it like:
>> coords: getLonLatFromPixel(e.xy.x, e.xy.y)
>> because it doesn´t work like that
>> ________________________________
>> Von: users-bounces at openlayers.org im Auftrag von Bart van den Eijnden
>> (OSGIS)
>> Gesendet: Mo 10.12.2007 13:59
>> An: Christopher Schmidt
>> Cc: users at openlayers.org
>> Betreff: Re: [OpenLayers-Users] different coords format
>> Hi Chris,
>> thanks for the clarification, so why is it labeled as an API Method if it
>> is
>> meant to be internal?
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl <http://www.osgis.nl/>
>> --------- Oorspronkelijk bericht --------
>> Van: Christopher Schmidt <crschmidt at metacarta.com>
>> Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
>> Cc: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>,
>> Onderwerp: Re: [OpenLayers-Users] different coords format
>> Datum: 10/12/07 10:56
>> > On Mon, Dec 10, 2007 at 01:19:26PM +0100, Bart van den Eijnden (OSGIS)
>> wrote:
>> > > You can use the function getLonLatFromViewPortPx on the map
>> object.
>> > actually, getLonLatFromPixel is the right function to use here:
>> > "FromViewPortPx" is a more internal function that we wrap up
>> with
>> > getLatLonFromPixel.
>> > Regards,
>> > Christopher Schmidt
>> > MetaCarta
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14252733.html
