[OpenLayers-Users] different coords format
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Dec 10 08:41:14 EST 2007
You're passing in the object, try something like:
var coords = window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y);
var request = window[id].getFullRequestString({
q_type: "0",
extent: window[id].map.getExtent().toBBOX(),
coords: coords.lon+","+coord.lat
Or the other way round (lon/lat) ...
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
Naar: users at openlayers.org <users at openlayers.org>
Onderwerp: Re: [OpenLayers-Users] different coords format
Datum: 10/12/07 11:37
> Here´s my request:
> q_type: "0",
> coords:
> window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y),
"http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation");
> the problem is still the coords, here´s the actuall request:
http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation&g=Abflussstation&i=png&transparent=true&q_type=0&extent=385077.280363%2C131098.74813%2C600412.719637%2C227054.25187&coords=lon%3DNaN%2Clat%3DNaN
> still something wrong with the coords, any idea?
> Pierre GIRAUD wrote:
> > You should have something better using :
> > Then you can access coords.x and corrds.y.
> > Regards
> > On Dec 10, 2007 2:05 PM, Ortner Reinhard
> > <Reinhard.Ortner at edu.fh-kaernten.ac.at> wrote:
> >> thx, but back to my question :)
> >> can i use it like:
> >> coords: getLonLatFromPixel(e.xy.x, e.xy.y)
> >> because it doesn´t work like that
> >> ________________________________
> >> Von: users-bounces at openlayers.org im Auftrag von Bart van den
Eijnden
> >> (OSGIS)
> >> Gesendet: Mo 10.12.2007 13:59
> >> An: Christopher Schmidt
> >> Cc: users at openlayers.org
> >> Betreff: Re: [OpenLayers-Users] different coords format
> >> Hi Chris,
> >> thanks for the clarification, so why is it labeled as an API
Method if it
> >> is
> >> meant to be internal?
> >> Best regards,
> >> Bart
> >> http://www.osgis.nl <http://www.osgis.nl/>
> >> Van: Christopher Schmidt <crschmidt at metacarta.com>
> >> Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
> >> Cc: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>,
> >> Datum: 10/12/07 10:56
> >> > On Mon, Dec 10, 2007 at 01:19:26PM +0100, Bart van den
Eijnden (OSGIS)
> >> wrote:
> >> > &gt; You can use the function getLonLatFromViewPortPx on
the map
> >> object.
> >> > actually, getLonLatFromPixel is the right function to use
here:
> >> > &quot;FromViewPortPx&quot; is a more internal
function that we wrap up
> >> with
> >> > getLatLonFromPixel.
> >> > Regards,
> >> > Christopher Schmidt
> >> > MetaCarta
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> >> Users mailing list
> > Users mailing list
http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14252733.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
