[OpenLayers-Users] different coords format
R. Ortner reinhard.ortner at edu.fh-kaernten.ac.at
Mon Dec 10 08:51:40 EST 2007
I tried that, heres my complete funktion:
function checkinfo(imgid,url,title){
if (infobox == 0) {infobox = 1;}
if (imgid == oldimgid) {infobox = 0;}
id = imgid.substring(3,imgid.length);
	 if(infobox == 1 && document.getElementById(id).checked==true) {
	 					document.getElementById('map').style.cursor = 'crosshair';
						document.getElementById(imgid).src = "img/treemenu/identify_2.gif";
        		if (oldimgid != null) document.getElementById(oldimgid).src =
"img/treemenu/identify_1.gif";
        		oldimgid = imgid;
        		document.getElementById('nodeList').style.visibility = 'visible';
    map.events.register('click', map, function (e) {
            OpenLayers.Util.getElement('nodeList').innerHTML = "Loading...
please wait...";
            var coords = window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y);
			var request =  window[id].getFullRequestString({
                            q_type: "0",
                            extent: window[id].map.getExtent().toBBOX(),
                            coords: coords.lon+","+coord.lat,
"http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation");
            OpenLayers.loadURL(request, '', this, setHTML);
            OpenLayers.Event.stop(e);
else {
	 					document.getElementById('map').style.cursor = 'auto';
			 			document.getElementById('nodeList').style.visibility = 'hidden';
			 			if (imgid == oldimgid) { oldimgid = null; } else { oldimgid = imgid;
						document.getElementById('nodeList').innerHTML = "";
			 			infobox = 0;
						document.getElementById(imgid).src = "img/treemenu/identify_1.gif";
function setHTML(response) {
   OpenLayers.Util.getElement('nodeList').innerHTML = response.responseText;
but now i get:
coord is not defined
[Break on this error] coords: coords.lon+","+coord.lat,
Bart van den Eijnden (OSGIS)-2 wrote:
> You're passing in the object, try something like:
> q_type: "0",
> Or the other way round (lon/lat) ...
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
> Naar: users at openlayers.org <users at openlayers.org>
> Onderwerp: Re: [OpenLayers-Users] different coords format
> Datum: 10/12/07 11:37
>> Here´s my request:
>>                             q_type: &quot;0&quot;,
>>                             coords:
>> window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y),
> &quot;http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&amp;groups=Abflussstation&quot;);
>> the problem is still the coords, here´s the actuall request:
> http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&amp;groups=Abflussstation&amp;g=Abflussstation&amp;i=png&amp;transparent=true&amp;q_type=0&amp;extent=385077.280363%2C131098.74813%2C600412.719637%2C227054.25187&amp;coords=lon%3DNaN%2Clat%3DNaN
>> still something wrong with the coords, any idea?
>> Pierre GIRAUD wrote:
>> &gt;
>> &gt; You should have something better using :
>> &gt;
>> &gt; var coords = window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y);
>> &gt;
>> &gt; Then you can access coords.x and corrds.y.
>> &gt;
>> &gt; Regards
>> &gt;
>> &gt; On Dec 10, 2007 2:05 PM, Ortner Reinhard
>> &gt; &lt;Reinhard.Ortner at edu.fh-kaernten.ac.at&gt; wrote:
>> &gt;&gt; thx, but back to my question :)
>> &gt;&gt;
>> &gt;&gt; can i use it like:
>> &gt;&gt;
>> &gt;&gt; coords: getLonLatFromPixel(e.xy.x, e.xy.y)
>> &gt;&gt;
>> &gt;&gt; because it doesn´t work like that
>> &gt;&gt;
>> &gt;&gt; ________________________________
>> &gt;&gt;
>> &gt;&gt; Von: users-bounces at openlayers.org im Auftrag von Bart van den
> Eijnden
>> &gt;&gt; (OSGIS)
>> &gt;&gt; Gesendet: Mo 10.12.2007 13:59
>> &gt;&gt; An: Christopher Schmidt
>> &gt;&gt; Cc: users at openlayers.org
>> &gt;&gt; Betreff: Re: [OpenLayers-Users] different coords format
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt; Hi Chris,
>> &gt;&gt;
>> &gt;&gt; thanks for the clarification, so why is it labeled as an API
> Method if it
>> &gt;&gt; is
>> &gt;&gt; meant to be internal?
>> &gt;&gt;
>> &gt;&gt; Best regards,
>> &gt;&gt; Bart
>> &gt;&gt;
>> &gt;&gt; --
>> &gt;&gt; Bart van den Eijnden
>> &gt;&gt; OSGIS, Open Source GIS
>> &gt;&gt; http://www.osgis.nl &lt;http://www.osgis.nl/&gt;
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt; --------- Oorspronkelijk bericht --------
>> &gt;&gt; Van: Christopher Schmidt &lt;crschmidt at metacarta.com&gt;
>> &gt;&gt; Naar: Bart van den Eijnden OSGIS &lt;bartvde at osgis.nl&gt;
>> &gt;&gt; Cc: R. Ortner &lt;reinhard.ortner at edu.fh-kaernten.ac.at&gt;,
>> &gt;&gt; users at openlayers.org
>> &gt;&gt; Onderwerp: Re: [OpenLayers-Users] different coords format
>> &gt;&gt; Datum: 10/12/07 10:56
>> &gt;&gt;
>> &gt;&gt; &gt; On Mon, Dec 10, 2007 at 01:19:26PM +0100, Bart van den
> Eijnden (OSGIS)
>> &gt;&gt; wrote:
>> &gt;&gt; &gt; &amp;gt; You can use the function getLonLatFromViewPortPx
>> on
> the map
>> &gt;&gt; object.
>> &gt;&gt; &gt;
>> &gt;&gt; &gt; actually, getLonLatFromPixel is the right function to use
> here:
>> &gt;&gt; &gt; &amp;quot;FromViewPortPx&amp;quot; is a more internal
> function that we wrap up
>> &gt;&gt; with
>> &gt;&gt; &gt; getLatLonFromPixel.
>> &gt;&gt; &gt;
>> &gt;&gt; &gt; Regards,
>> &gt;&gt; &gt; --
>> &gt;&gt; &gt; Christopher Schmidt
>> &gt;&gt; &gt; MetaCarta
>> &gt;&gt; &gt;
>> &gt;&gt; &gt;
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt; _______________________________________________
>> &gt;&gt; Users mailing list
>> &gt;&gt; Users at openlayers.org
>> &gt;&gt; http://openlayers.org/mailman/listinfo/users
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt;
>> &gt;
>> &gt;
>> View this message in context:
> http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14252733.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
> Users mailing list
View this message in context: http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14253189.html
