[OpenLayers-Users] different coords format
Brent Pedersen
bpederse at gmail.com
Mon Dec 10 12:12:54 EST 2007
hi, in someplaces you use coord, and in others coords as this messge tells:
coord is not defined
[Break on this error] coords: coords.lon+","+coord.lat,
On Dec 10, 2007 5:51 AM, R. Ortner
<reinhard.ortner at edu.fh-kaernten.ac.at> wrote:
> I tried that, heres my complete funktion:
> function checkinfo(imgid,url,title){
> if (infobox == 0) {infobox = 1;}
> if (imgid == oldimgid) {infobox = 0;}
> id = imgid.substring(3,imgid.length);
> if(infobox == 1 && document.getElementById(id).checked==true) {
> document.getElementById('map').style.cursor = 'crosshair';
> document.getElementById(imgid).src = "img/treemenu/identify_2.gif";
> if (oldimgid != null) document.getElementById(oldimgid).src =
> "img/treemenu/identify_1.gif";
> oldimgid = imgid;
> document.getElementById('nodeList').style.visibility = 'visible';
> map.events.register('click', map, function (e) {
> OpenLayers.Util.getElement('nodeList').innerHTML = "Loading...
> please wait...";
> var coords = window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y);
> var request = window[id].getFullRequestString({
> q_type: "0",
> extent: window[id].map.getExtent().toBBOX(),
> "http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation");
> OpenLayers.loadURL(request, '', this, setHTML);
> OpenLayers.Event.stop(e);
> else {
> document.getElementById('map').style.cursor = 'auto';
> document.getElementById('nodeList').style.visibility = 'hidden';
> if (imgid == oldimgid) { oldimgid = null; } else { oldimgid = imgid;
> document.getElementById('nodeList').innerHTML = "";
> infobox = 0;
> document.getElementById(imgid).src = "img/treemenu/identify_1.gif";
> function setHTML(response) {
> OpenLayers.Util.getElement('nodeList').innerHTML = response.responseText;
> but now i get:
> Bart van den Eijnden (OSGIS)-2 wrote:
> > You're passing in the object, try something like:
> > q_type: "0",
> > Or the other way round (lon/lat) ...
> > Bart
> > OSGIS, Open Source GIS
> > http://www.osgis.nl
> > --------- Oorspronkelijk bericht --------
> > Van: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>
> > Naar: users at openlayers.org <users at openlayers.org>
> > Onderwerp: Re: [OpenLayers-Users] different coords format
> > Datum: 10/12/07 11:37
> >> Here´s my request:
> >> q_type: "0",
> >> coords:
> >> window[id].map.getLonLatFromPixel(e.xy.x, e.xy.y),
> >> the problem is still the coords, here´s the actuall request:
> > http://172.21.18.45/ka-map/map_query_float.php?map=geoland_test&groups=Abflussstation&g=Abflussstation&i=png&transparent=true&q_type=0&extent=385077.280363%2C131098.74813%2C600412.719637%2C227054.25187&coords=lon%3DNaN%2Clat%3DNaN
> >> still something wrong with the coords, any idea?
> >> Pierre GIRAUD wrote:
> >> > You should have something better using :
> >> > Then you can access coords.x and corrds.y.
> >> > Regards
> >> > On Dec 10, 2007 2:05 PM, Ortner Reinhard
> >> > <Reinhard.Ortner at edu.fh-kaernten.ac.at> wrote:
> >> >> thx, but back to my question :)
> >> >> can i use it like:
> >> >> coords: getLonLatFromPixel(e.xy.x, e.xy.y)
> >> >> because it doesn´t work like that
> >> >> ________________________________
> >> >> Von: users-bounces at openlayers.org im Auftrag von Bart van den
> > Eijnden
> >> >> (OSGIS)
> >> >> Gesendet: Mo 10.12.2007 13:59
> >> >> An: Christopher Schmidt
> >> >> Cc: users at openlayers.org
> >> >> Betreff: Re: [OpenLayers-Users] different coords format
> >> >> Hi Chris,
> >> >> thanks for the clarification, so why is it labeled as an API
> > Method if it
> >> >> is
> >> >> meant to be internal?
> >> >> Best regards,
> >> >> Bart
> >> >> http://www.osgis.nl <http://www.osgis.nl/>
> >> >> Van: Christopher Schmidt <crschmidt at metacarta.com>
> >> >> Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
> >> >> Cc: R. Ortner <reinhard.ortner at edu.fh-kaernten.ac.at>,
> >> >> Datum: 10/12/07 10:56
> >> >> > On Mon, Dec 10, 2007 at 01:19:26PM +0100, Bart van den
> > Eijnden (OSGIS)
> >> >> wrote:
> >> >> > &gt; You can use the function getLonLatFromViewPortPx
> >> on
> > the map
> >> >> object.
> >> >> > actually, getLonLatFromPixel is the right function to use
> > here:
> >> >> > &quot;FromViewPortPx&quot; is a more internal
> > function that we wrap up
> >> >> with
> >> >> > getLatLonFromPixel.
> >> >> > Regards,
> >> >> > Christopher Schmidt
> >> >> > MetaCarta
> >> >> _______________________________________________
> >> >> Users mailing list
> >> >> Users at openlayers.org
> >> >> http://openlayers.org/mailman/listinfo/users
> >> >> Users mailing list
> >> > Users mailing list
> >> View this message in context:
> > http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14252733.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> Users mailing list
> > Users mailing list
> View this message in context: http://www.nabble.com/Re%3A-different-coords-format-tp14251954p14253189.html
> Users mailing list
