[OpenLayers-Users] SVG Overlay
Pierre GIRAUD
bluecarto at gmail.com
Wed Dec 12 17:51:53 EST 2007
You have to think the vector point elements as markers. You can
already add style to them (size, color, offset(?)). The x, y
coordinates are given by the feature geometry.
I prefered to use a (static ?) catalog but your approach seems
interesting too. This would allow user to get symbols which number he
doesn't know in advance or created on-the-fly.
On Dec 12, 2007 11:38 PM, miles <miles.togoe at gmail.com> wrote:
> Pierre GIRAUD wrote:
> > I'm just wondering if you noticed that we are using a svg symbols catalogue.
> > http://dev.openlayers.org/sandbox/camptocamp/vectorSymbols/examples/symbol_catalog.svg
> ahh, okay, maybe this is what I'm trying to figure out - I can see the
> usefulness for many people of having a ready-to-use symbol library. But
> since there's obviously code that translates SVG from the symbol
> library, couldn't there be or is there an api call that imports directly
> from a separate SVG file rather than from the symbol library - thus,
> instead of having to put a dynamically created SVG in the symbol
> library, we could just call something like map.importsvg(mysvg,
> x,y,scale,rotate) - then the SVG import file gets the advantage of being
> geo-positioned (if that is the right term) and converted to VML, if IE.
> > Regards,
> > Pierre
> >>> If you need vector symbols you should have a look at this example.
> >>> http://dev.openlayers.org/sandbox/camptocamp/vectorSymbols/examples/vector-symbols.html
> >> This seems backwards to me to have to replicate graphic or symbol
> >> libraries in yet another graphics api - if we're outputting dynamic
> >> graphics in SVG in our code, now we have to change our output code to
> >> OpenLayers vector language ? Which then converts it back to SVG ?
> >> duh? The advantage of using an open xml standard like SVG is that it
> >> can be displayed not just on the screen in OpenLayers but converted via
> >> ImageMagik, saved to an xml output file to be used in Inkscape (or even
> >> in a text editor), or in reverse, created in Inkscape and brought in
> >> from there, and likewise used in other programs. I'm starting to
> >> wonder if we should or need to patch or fork a version of OpenLayers
> >> with direct handling of SVG ?
> >>> Two notes :
> >>> - This only works for point features,
> >>> - this converts svg symbols into vml groups so that they can be
> >>> rendered into IE.
> >>> Regards,
> >>> Pierre
> >>> On Dec 12, 2007 9:28 PM, miles <miles.togoe at gmail.com> wrote:
> >>>> Tim Schaub wrote:
> >>>>> Hey-
> >>>>> miles wrote:
> >>>>>> Are there any examples of using a SVG overlay? I didn't see any. I
> >>>>>> suspect it's kind of tricky since I assume the SVG coordinate system
> >>>>>> would need to be translated to the coordinate system/projection being
> >>>>>> used for the base layer.
> >>>>> If you open the following page in Firefox, you're looking at an "SVG
> >>>>> overlay."
> >>>>> http://openlayers.org/dev/examples/rotate-features.html
> >>>>> Did you mean something different?
> >>>> yes, I realize OpenLayers renders in SVG or VML but I meant overlaying
> >>>> an actual SVG xml file. This would permit displaying icons made in
> >>>> Inkscape, etc and I would think be faster since OpenLayers does not have
> >>>> to convert the vector language code to SVG. Obviously it would only
> >>>> display in a browser that supports SVG - or should we say won't display
> >>>> in IE, the only browser that does not support SVG ):
> >>>> <?xml version="1.0" encoding="UTF-8" standalone="no"?>
> >>>> <!-- Created with Inkscape (http://www.inkscape.org/) -->
> >>>> <svg
> >>>> xmlns:svg="http://www.w3.org/2000/svg"
> >>>> xmlns="http://www.w3.org/2000/svg"
> >>>> version="1.0"
> >>>> width="744.09448"
> >>>> height="1052.3622"
> >>>> id="svg2">
> >>>> <defs
> >>>> id="defs4" />
> >>>> <g
> >>>> id="layer1">
> >>>> <path
> >>>> d="M 231.42858 336.64789 A 48.57143 47.142857 0 1 1
> >>>> 134.28572,336.64789 A 48.57143 47.142857 0 1 1 231.42858 336.64789 z"
> >>>> style="fill:#ff0000;fill-rule:evenodd;stroke:#000000;stroke-width:1px;stroke-linecap:butt;stroke-linejoin:miter;stroke-opacity:1"
> >>>> id="path2160" />
> >>>> </g>
> >>>> </svg>
> >>>> _______________________________________________
> >>>> Users mailing list
> >>>> Users at openlayers.org
> >>>> http://openlayers.org/mailman/listinfo/users
