[OpenLayers-Users] Google and GML layer
Arnd Wippermann
arnd.wippermann at web.de
Thu Dec 13 17:23:40 EST 2007
to transform my data from EPSG:31466 to EPSG:900913 with ogr2ogr, I have
experienced the same shift. After some search i found this "Add 900913 EPSG
code to cubewerks_extra file" (http://trac.osgeo.org/gdal/ticket/1868) and
tried this. Now the reprojection returns the right values.
With MapServer WFS I had no problem to retrieve the right values after
adding 900913 to the epsg-file, also using ogr as connection to an odbc-db.
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
Yves Jacolin wrote:
> Le Thursday 06 December 2007 14:58:46 Christopher Schmidt, vous avez
> écrit :
>> On Thu, Dec 06, 2007 at 02:54:46PM +0100, Jacolin Yves wrote:
>> > Hi,
>> > One ofmy friend is trying to create a map with a Google layer as
>> > baseLayer and he added a GML layer. I converted his shapefile from
>> WGS84
>> > to
>> > SphericalMercator with ogr then he converted it in GML file.
>> > The map is ok except for the GML layer where there is still an
>> y-offset.
>> > Do you know what we forgot to do?
>> My first instinct would be to blame your transformation. How did you
>> transform it from 4326 to spherical mercator?
>> Regards,
> Something like this :
> ogr2ogr -f "ESRI Shapefile" -t_srs "+proj=merc +a=6378137 +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
> +no_defs" -s_srs "EPSG:4326" Mono2006_2.shp Mono2006_region.shp
> Am I wrong?
> Y.
> Yves Jacolin
> http://softlibre.gloobe.org
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Google-and-GML-layer-tp14192810p14326074.html
