[OpenLayers-Users] get feature info select box
    bradleyspencer
    brad at cubewerx.com.au
    Fri Dec 14 02:25:08 EST 2007
Christopher,
Thanks for this it worked really well, I just loaded this new control at OL
loadmap time. However, I have a small problem. When I use the mouse drag
zoom control it appears to over ride this new control making it non
functional after the use of that zoom control. Does that sound right and
what would you suggest I do to manage this?
Cheers,
Brad Spencer
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Tuesday, 11 December 2007 10:09 AM
To: bradleyspencer
Cc: openlayers users
Subject: Re: [OpenLayers-Users] get feature info select box
On Tue, Dec 11, 2007 at 09:50:07AM +1100, bradleyspencer wrote:
> List,
> Has anyone got an example of how to use the mouse to drag a
rectangle/square
> over the map area which then can be used to intersect with map objects
such
> as server-side polygons?
> I really just want a client tool to generate the drag box and expose the
> BBox in real map coords. I can then stuff these into a filtered GetFeature
> request to snare all the objects I want.
Shift-drag on http://openlayers.org/dev/examples/custom-control.html
does what you want, I think.
Regards,
Christopher Schmidt
MetaCarta
