[OpenLayers-Users] Different behavior of WFS layer in IE 7
andFirefox
bradleyspencer
brad at cubewerx.com.au
Tue Dec 18 16:19:35 EST 2007
Christian,
I have been able to overlay vectors from a WFS request over GoogleMaps using
default EPSG:4326 in IE7 quite OK. When doing this in FF it is overlayed but
is clearly not in the right position/orientation/scale therefore projection
problem).
I have not used sphericalMercator as I need to overlay data from WMS
services that do not support EPSG:900913.
CubeWerx supports this projection but other remote services that I am using
do not so I am intending to cascade through CubeWerx WMS to handle this
projection.
But I do not understand why if it works in IE it does not also work in FF
the same?
Cheers,
Brad Spencer
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]On
Behalf Of Christopher Schmidt
Sent: Wednesday, 19 December 2007 7:10 AM
To: Yingqi Tang
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] Different behavior of WFS layer in IE 7
andFirefox
On Tue, Dec 18, 2007 at 11:57:22AM -0800, Yingqi Tang wrote:
> List,
> I noticed a different behavior of a WFS layer between IE7 and Firefox. I
> basically added a point feature type WFS layer on a Google Maps base
layer,
> and I didn't specify "featureClass" to OpenLayers.Feature.WFS, so I assume
> OpenLayers.Feature.Vector will be used. The problem is when I pan the map
in
> Firefox the WFS layer is not moving as it should because the positions of
> point features on base layer changed after I pan. But if I tried the same
> thing in IE7 it just works perfect.
> Does anyone have clue on why this is happening and is there any way to
work
> around it?
Vectors can't be used over Google Maps unless Spherical Mercator is
being used.
Regards,
Christopher Schmidt
MetaCarta
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
