[OpenLayers-Users] Any examples using Proj4js
and OpenLayers.Projection class?
Mike Adair
madair at dmsolutions.ca
Mon Dec 24 11:04:32 EST 2007
Steve,
I've updated Proj4js with the proj4 version of the stereographic
projection and my test point now comes out at the correct location.
You can get the update at
https://svn.codehaus.org/mapbuilder/cscs/trunk/proj4js/lib and use the
file proj4js-compressed.js (or proj4js-combined.js if you want to debug
what's going on inside). Compressed and combined versions of proj4js
include all files required.
Let me know if that works for you.
Mike
Steve Lime wrote:
> I'm working with openlayers trunk trying to get some point projection to work. Code like this:
> <!-- pt src="scripts/openlayers/lib/OpenLayers.js"></scr -->
> <!-- pt src="scripts/proj4js/lib/proj4js.js"></scr -->
> <!-- pt src="scripts/proj4js/lib/projCode/stere.js"></scr -->
> map = new OpenLayers.Map( $('map'), {maxExtent: new OpenLayers.Bounds(-2668252.000000,-2707008.500000,2813685.000000,2774928.500000),
> maxResolution: 10706.9082, units: 'm', projection: 'EPSG:3031'} );
> Proj4js.defs['EPSG:3031'] = '+proj=stere +lat_0=-90 +lat_ts=-71 +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs'; // Antarctica Polar Stereographic
> var wgs84 = new OpenLayers.Projection('WGS84');
> var point = new OpenLayers.Geometry.Point(lon, lat);
> OpenLayers.Projection.transform(point, wgs84, map.getProjection());
> alert(point.x +" "+ point.y);
> doesn't seem to work, the x, y members remain unchanged. Any ideas?
> Thanks!
> Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
