[OpenLayers-Users] Any examples using
Proj4js and OpenLayers.Projection class?
Steve Lime
Steve.Lime at dnr.state.mn.us
Fri Dec 28 12:08:53 EST 2007
Mike: I wanted to let you know that the forward transformation does indeed
work, thanks. I wasn't able to go the other way.
Proj4js.defs['EPSG:3031'] = '+proj=stere +lat_0=-90 +lat_ts=-71 +lon_0=0 +k=1 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs'; // Antarctica Polar Stereographic
var wgs84 = new OpenLayers.Projection('WGS84');
var point = new OpenLayers.Geometry.Point(lon, lat);
OpenLayers.Projection.transform(point, wgs84, map.getProjectionObject()); // forward
alert(point.x +" "+ point.y); // correct
OpenLayers.Projection.transform(point, map.getProjectionObject(), wgs84); // reverse
alert(point.x +" "+ point.y); // no change, expect the original lat/lon
It's not a big deal for me since I really only need the forward transformation...
Thanks for the hard work!
Steve
>>> On 12/24/2007 at 10:04 AM, in message <476FD890.3040902 at dmsolutions.ca>, Mike
Adair <madair at dmsolutions.ca> wrote:
> Steve,
> I've updated Proj4js with the proj4 version of the stereographic
> projection and my test point now comes out at the correct location.
> You can get the update at
> https://svn.codehaus.org/mapbuilder/cscs/trunk/proj4js/lib and use the
> file proj4js-compressed.js (or proj4js-combined.js if you want to debug
> what's going on inside). Compressed and combined versions of proj4js
> include all files required.
> Let me know if that works for you.
> Mike
> Steve Lime wrote:
>> I'm working with openlayers trunk trying to get some point projection to
> work. Code like this:
>> <!-- pt src="scripts/openlayers/lib/OpenLayers.js"></scr -->
>> <!-- pt src="scripts/proj4js/lib/proj4js.js"></scr -->
>> <!-- pt src="scripts/proj4js/lib/projCode/stere.js"></scr -->
>> map = new OpenLayers.Map( $('map'), {maxExtent: new
> OpenLayers.Bounds(-2668252.000000,-2707008.500000,2813685.000000,2774928.5000
> 00),
>> maxResolution: 10706.9082,
> units: 'm', projection: 'EPSG:3031'} );
> Polar Stereographic
>> OpenLayers.Projection.transform(point, wgs84, map.getProjection());
>> doesn't seem to work, the x, y members remain unchanged. Any ideas?
>> Thanks!
>> Steve
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
