[OpenLayers-Users] Mapserver vs WMS.layer
Maria Panagou
snowdrop at ath.forthnet.gr
Fri Dec 28 11:47:49 EST 2007
I've declared a wms layer using the following syntax, which works fine.
var quakes = new OpenLayers.Layer.WMS( "Earthquakes",
"http://127.0.0.1:80/cgi-bin/mapserv.exe?",
{ map: '../htdocs/mpanagou/Quakes original.map',
transparent:'true',
layers: 'Quakes',
'format':'png'},
{'reproject': true});
I want to test this, using Mapserver layer instead so I replace new
OpenLayers.Layer.WMS with new OpenLayers.Layer.Mapserver, but the map won't
show at all. Do I need to use different parameters for the mapserver layer?
The reason I want to test that is that WMS layer is too slow. I tried the
untiled or singletile:'true' options but I see no difference.
View this message in context: http://www.nabble.com/Mapserver-vs-WMS.layer-tp14528042p14528042.html
