[OpenLayers-Users] Mapserver vs WMS.layer
David William Bitner
david.bitner at gmail.com
Fri Dec 28 11:54:00 EST 2007
It's still using MapServer, so changing layer type shouldn't make a
difference. Tuning your MapServer by creating indexing, scale dependent
layering, generalizing, etc. will be the things that will make your
MapServer faster. Alternatively (or in addition) you could look into a
tiling engine like TileCache to prerender tiles.
On Dec 28, 2007 10:47 AM, Maria Panagou <snowdrop at ath.forthnet.gr> wrote:
> I've declared a wms layer using the following syntax, which works fine.
> var quakes = new OpenLayers.Layer.WMS( "Earthquakes",
> "http://127.0.0.1:80/cgi-bin/mapserv.exe?",
> { map: '../htdocs/mpanagou/Quakes original.map',
> transparent:'true',
> layers: 'Quakes',
> 'format':'png'},
> {'reproject': true});
> I want to test this, using Mapserver layer instead so I replace new
> OpenLayers.Layer.WMS with new OpenLayers.Layer.Mapserver, but the map
> won't
> show at all. Do I need to use different parameters for the mapserver
> layer?
> The reason I want to test that is that WMS layer is too slow. I tried the
> untiled or singletile:'true' options but I see no difference.
> http://www.nabble.com/Mapserver-vs-WMS.layer-tp14528042p14528042.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20071228/b3ef16f7/attachment.html
