[OpenLayers-Users] TC updates
Bill Woodall bwoodall at wardrobe.dhs.org
Wed Feb 7 05:40:02 EST 2007
Hi Christopher,
Here is blurp on using Client.py seed
The code changes will have to be in 1.5, since I'm not
sure of them
.......Bill,
diff -rcwb tilecache-1.4/README tilecache-1.4_bw/README
*** tilecache-1.4/README        2007-02-03 19:17:55.000000000 -0800
--- tilecache-1.4_bw/README     2007-02-07 02:35:31.000000000 -0800
*** 199,202 ****
--- 199,238 ----
  tilecache.py. Similarly, you would need to edit this URL if you were
to use
  TileCache with the standalone HTTP Server or FastCGI.
+ ***  Make sure the Openlayer maxExtent is the same as bbox in
tilecache.cfg ***
+ To use TileCache to seed your cache
+  * Set up the tilecache.cfg if you have not already done so in one of
the
+    above configurations
+  * In /var/www/tilecache/TileCache,  where /var/www/tilecache is the
+    directory resulting from the code extraction.
+  * The syntax is in the form of;
+ <path to>python ./Client.py <url> <layer> <zoom start> <zoom stop>
<bbox>
+    where:
+    url -- http://example.com/yourdir/tilecache.cgi? or
+           http://example.com/yourdir/tilecache.py
+    layer -- same layer name that is in the tilecache.cfg
+    zoom start -- Zoom level to start the process
+    zoom end -- Zoom level to end the process
+    bbox -- The bounding box (see the *** note *** above)
+   An example with zoom levels 5 through 12 would be like;
+ /usr/bin/python ./Client.py
"http://example.com/yourdir/tilecache.cgi?"
+      Zip_Codes 5 12
"-118.12500,31.952162238,-116.015625,34.3071438563"
+   The bbox can be dropped and defaults to world
lonlat(-180,-90,180,90)
+      Zip_Codes 9
