[OpenLayers-Users] when panning E/W, map shifts in Y direction
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Feb 19 03:08:57 EST 2007
Hi Christopher, list,
I've tested this with 2.3RC3 this morning and the problem is still there
(1=initial, 2=pan 4 times east, 3=pan 4 times west again).
1: BBOX=111645.979497,503397.695033,112524.885747,504031.32512
2: BBOX=113406.936564,503400.839599,114285.842814,504034.469686
3: BBOX=111652.26863,503403.984165,112531.17488,504037.614253
Now there is even a change in the X-direction which was not there before.
The change in the Y-direction seems less though.
Thanks in advance.
Best regards,
Bart
On Fri, Feb 16, 2007 at 05:22:45PM +0100, Bart van den Eijnden (OSGIS)
wrote:
> I've done some more analysis, this is only happens when the map width
and/or
> height is an odd number.
Bart --
This is fixed in OpenLayers 2.3-rc3, released about 10 minutes ago.
Please let me know if this does not fix the problem for you.
Christopher Schmidt
MetaCarta
OSGIS, Open Source GIS
http://www.osgis.nl
