[OpenLayers-Users] [Fwd: [ka-Map-users] Speeding up
tile display/download]
Graham Davis
gdavis at refractions.net
Mon Feb 19 12:16:25 EST 2007
Chris,
I was looking at adding this support as well, but I'm glad to see it is
already done. I'm working from the vector branch of code, so if I want
to use the changes made for this feature can I just copy one or a few
files from the 2.3 branch? Which files would I need and should the
changes be localised enough within those files that I can easily just
replace the versions I have? Thanks,
Graham Davis
Refractions Research Inc.
Christopher Schmidt wrote:
>On Sat, Feb 17, 2007 at 03:16:59PM -0500, Stephen Woodbridge wrote:
>>Is this easy to do with OpenLayers? What would be invovled?
>It's in OpenLayers 2.3. Simply specify a list of URLs for your layer
>instead of a single URL. http://labs.metacarta.com/wms-c/demo.html shows
>an example of it in use.
>>tileURL is now an array that holds 4 server names that are basically
>>only cnames in the dns server to the same server.
>>The setTile() function was modified to sequential build the img.src like
>>this (this is only the last part of the function):
>Regards,
