[OpenLayers-Users] [Fwd: [ka-Map-users] Speeding up
tile display/download]
Christopher Schmidt
crschmidt at metacarta.com
Mon Feb 19 13:37:17 EST 2007
On Mon, Feb 19, 2007 at 09:16:25AM -0800, Graham Davis wrote:
> Chris,
> I was looking at adding this support as well, but I'm glad to see it is
> already done. I'm working from the vector branch of code, so if I want
> to use the changes made for this feature can I just copy one or a few
> files from the 2.3 branch? Which files would I need and should the
> changes be localised enough within those files that I can easily just
> replace the versions I have? Thanks,
Ticket is:
http://trac.openlayers.org/ticket/399
Patch is:
http://trac.openlayers.org/attachment/ticket/399/multiserver.patch
This means that you should only need to change Layer.HTTPRequest, with
that patch, and you'd have that functionality.
However, I know nothing about the Vector branch, so I don't know if it
applies cleanly.
Regards,
Christopher Schmidt
MetaCarta
