[OpenLayers-Users] [Fwd: [ka-Map-users] Speeding up
tile display/download]
Graham Davis
gdavis at refractions.net
Mon Feb 19 13:51:27 EST 2007
Thanks Chris.
I've looked at the patch code and the code in the vector branch's
HTTPRequest.js file and it seems the branch already has your patch. So
if anyone else it curious, the vector branch already has support for
layers with multiple urls (I just didn't realize it). Cheers.
Graham Davis
Christopher Schmidt wrote:
>On Mon, Feb 19, 2007 at 09:16:25AM -0800, Graham Davis wrote:
>>Chris,
>>I was looking at adding this support as well, but I'm glad to see it is
>>already done. I'm working from the vector branch of code, so if I want
>>to use the changes made for this feature can I just copy one or a few
>>files from the 2.3 branch? Which files would I need and should the
>>changes be localised enough within those files that I can easily just
>>replace the versions I have? Thanks,
>Ticket is:
>http://trac.openlayers.org/ticket/399
>Patch is:
>http://trac.openlayers.org/attachment/ticket/399/multiserver.patch
>This means that you should only need to change Layer.HTTPRequest, with
>that patch, and you'd have that functionality.
>However, I know nothing about the Vector branch, so I don't know if it
>applies cleanly.
>Regards,
Graham Davis
Refractions Research Inc.
