[OpenLayers-Users] Overview Map Question
Christian López Espínola
penyaskito at gmail.com
Mon Jan 8 12:30:14 EST 2007
Maybe you are using the SAME layer in the map and in the overviewmap,
and this make you have this headaches. Try adding the overview map a
layer.clone().
Hope this helps.
On 1/5/07, Tim Schaub <noreply at geocartic.com> wrote:
> If I switch the two layers and have my own wms layer as the base layer and
> the above mentioned as overlay – the overlay map doesn't work anymore.
> Any help on that?
> -Hans
> Can you post a concise example that shows the problem? The overview map
> should work as any other map - with multiple layers if that's what you want.
> Tim
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Regards,
