[OpenLayers-Users] Overview Map Question
Robert Buzink
post at robertbuzink.nl
Mon Jan 8 19:43:12 EST 2007
As I said before, I had the same problem as you, Hans. I solved it by
replacing:
map.addControl(new OpenLayers.Control.OverviewMap());
with:
var ov = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} );
var options = {
layers: [ov.clone()],
minRatio: 8,
maxRatio: 128
map.addControl(new OpenLayers.Control.OverviewMap(options));
as Christian López Espínola suggested. I still don't understand why the
default doesn't work. Maybe this should be changed? Now it only works for
people who really understand what they are doing, and not for technical-lego
kids like me :-).
Thanks for the help!
On 1/8/07, Christian López Espínola <penyaskito at gmail.com> wrote:
> Maybe you are using the SAME layer in the map and in the overviewmap,
> and this make you have this headaches. Try adding the overview map a
> layer.clone().
> Hope this helps.
> On 1/5/07, Tim Schaub <noreply at geocartic.com> wrote:
> > If I switch the two layers and have my own wms layer as the base layer
> and
> > the above mentioned as overlay – the overlay map doesn't work anymore.
> > Any help on that?
> > -Hans
> > Can you post a concise example that shows the problem? The overview
> map
> > should work as any other map - with multiple layers if that's what you
> want.
> > Tim
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Regards,
> Users mailing list
Robert Buzink, website ontwerp en ontwikkeling
Sint-Pietersaalststraat 123
9000 Gent
+32 (0)9 33 00 267
+32 (0)487 548 414
robertbuzink.nl/webdesign
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070109/8918f073/attachment.html
