[OpenLayers-Users] Tilecache tile index clarification
Christopher Schmidt
crschmidt at metacarta.com
Tue Jan 9 09:28:01 EST 2007
On Tue, Jan 09, 2007 at 02:10:52PM -0000, joanne cook wrote:
> Hi All,
> I am slowly making progress getting tilecache 1.3 working on windows XP with apache 2.3. I have got to the stage where I can see the example URLs, and I'm trying to set up my own mapserver wms example. I have a valid wms server running, serving one layer, using projection EPSG:27700. If I use the URL
> http://localhost/tilecache-1.3/tilecache.py/1.0.0/Raster250K/0/0/0.png
> I can see one tile showing me the whole of my raster layer.
> However if I try and call it using a variant on:
> http://localhost/tilecache-1.3/tilecache.py?LAYERS=Raster250K&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:27700&BBOX=-3.57463,53.4869,-2,55.2941&SIZE=256,256
> Then I get the following error message:
> An error occurred: couldn't calculate tile index for layer Raster250K from ([-3.57463, 53.486899999999999, -2.0, 55.2941])
> File "C:\xampp\htdocs\tilecache-1.3\TileCache\Service.py", line 398, in modPythonHandler
> host )
> File "C:\xampp\htdocs\tilecache-1.3\TileCache\Service.py", line 377, in dispatchRequest
> tile = WMS(self).parse(params, path_info, host)
> File "C:\xampp\htdocs\tilecache-1.3\TileCache\Service.py", line 118, in parse
> return self.getMap(param)
> File "C:\xampp\htdocs\tilecache-1.3\TileCache\Service.py", line 127, in getMap
> % (layer.name, bbox)
> I am confused as to the projection that my bounding box coordinates should be in, and have tried them in EPSG 27700 and 4326. The above are the lat and long coordinates taken straight from the GetCapabilities xml file. I'm only assuming that's the problem though- my apache error log shows plenty of activity for the first URL above, and nothing for the second.
Can you paste the configuration section of your tilecache.cfg that
pertains to this layer in an email?
Regards,
Christopher Schmidt
MetaCarta
