[OpenLayers-Users] map.toJSONString, too much recursion
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Wed Jan 10 12:25:23 EST 2007
Hi Tim,
I would be very interested in this. Are you able to e-mail me the code,
or provide it in some other way?
Currently, I use PHP/Mapscript on the server-side to read in a WMC,
create a MAP file, and then convert the MAP file to OpenLayers
javascript objects. That works pretty fine. But I haven't got a way yet
to go from OpenLayers objects to WMC for interaction with a print
service. My interest is mainly WMS layers though.
Thanks in advance.
Best regards,
Bart
Tim Schaub schreef:
>> okay, are there plans for adding a toJSONString function to
>> the Map object in OpenLayers? Or does anyone have one lying
> The WMC spec has some promise here. I've got a half baked control lying
> around on the shelf that creates a WMC doc given the state of the map. The
> doc is maintained as a JSON data structure that can be translated to XML.
> The same control would parse WMC docs (converting the XML to JSON) and set
> the map state.
> If anyone is significantly motivated, this could be finished. (Decisions
> would have to be made on how to extend WMC to handle OL specific stuff - but
> it is set up for that.)
> Tim
>> Best regards,
>> Bart
>> Christopher Schmidt schreef:
>>> On Wed, Jan 10, 2007 at 01:00:38PM +0100, Bart van den
>> Eijnden (OSGIS) wrote:
>>>> Hi list,
>>>> I am trying to get the OpenLayers map object as a JSON
>> string (using
>>>> http://www.json.org/json.js), but I get too much recursion
>> errors in
>>>> both IE and Firefox.
>>> The OpenLayers Map object has recursive references. Using
>> toJSONString
>>> from JSON.org will probably not work.
>>> Regards,
>> OSGIS, Open Source GIS
>> bartvde at osgis.nl
>> http://www.osgis.nl
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
bartvde at osgis.nl
http://www.osgis.nl
