[OpenLayers-Users] Problem with markers performence
suneel kota suneel.kota at gmail.com
Thu Jan 11 05:47:36 EST 2007
Hi Christopher,
Thaks for your help.. Its taking less time in Morzila. But My requirement is
to run it in IE. If you get any idea please mail me..
Thanks a lott... and thaks to the openlayers users..
Regards
SuneelKota
On 1/9/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Jan 09, 2007 at 12:00:56PM +0530, suneel kota wrote:
> > Hi Christopher, Thanks for ur reply..
> >                I am using IE for displaying the markers.. With out
> parsing
> > the xml file how can i get the latitude and longitude to display the
> markers
> > on the map..
> If you are using IE, you are running into limitations in IE's
> implementation of transparent image handling. There is no way to speed
> up the addition of hundreds of alpha-transparent images to the map in
> IE.
> >               Is there any other way to display lot of markers on the
> map.
> > I tried using text file and xml file with openlayers api.. Even its
> taking
> > much time..
> Yes, it's a limitation of the browser, not your particular method of
> adding the markers. If you were to try it in Firefox, I think you would
> see a much more managable timeframe for adding hundreds of markers --
> though more than 500 is not well supported.
> The solution to this may be for you to investigate an imagemap based
> solution to the problem. Others on the list have expressed an interest
> in this type of solution as well -- you might want to look through the
> list archives or send out an email asking if anyone else is interested
> in working on a solution to the problem.
> At the moment, OpenLayers does not have a solution for the problem you
> want to solve. If you find a way to solve it, the solution would
> probably be something generally useful, and worth contributing back to
> the core.
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070111/52fed0a3/attachment.html
