[OpenLayers-Users] GeoRSS and layers
Yves Jacolin
yjacolin at free.fr
Mon Jan 15 11:17:45 EST 2007
I am just posting in users openlayers mailing list, I have not subscribe to
the georss mailing list yet.
Well, my problem is definitively my knowledge about javascript ;-)
I am a newby for both javascript and geoRSS so sorry for my basic question. I
studied some documentation about georss and some georss file find out in the
web. I will follow the discussion in georss mailing list.
Anyway, thank you for your answer !
Y.
Le Lundi 15 Janvier 2007 16:45, Christopher Schmidt a écrit :
> To the GeoRSS list:
> These questions came up on the OpenLayers users list, but they are
> general questions on use of GeoRSS more than OpenLayers implementation
> questions. If you have thoughts on the answers to these questions, I
> would love to hear them. Please follow up to the GeoRSS list.
> Thanks.
> On Mon, Jan 15, 2007 at 03:56:34PM +0100, Yves Jacolin wrote:
> > Hi,
> > I would like to load a GeoRSS url with several channels. For each
> > channel, I would like a sp?cific layer in the layer control bar. But the
> > actual geoRSS javascript file load all items in one layer.
> > Do you have any ideas to modify the georss.js file to load one layer for
> > each channel nodes ?
> Multiple channels in one RSS file is, as far as I'm aware, a violation
> of the RSS specification. If you can point to a place where this type of
> behavior is defined, we can investigate adding support for it.
> If I were to implement it, I would probably simply add multiple layers,
> one for each channel (and having multiple files to contain that data).
> Is there a reason that doesn't work for you?
> > Furthermore, do you know if it is "possible" to add an icon tags for
> > example to modify icons for each item ? I modified my georss.xml response
> > to get something like :
> > <item>
> > <title>titre</title>
> > <link>link</link>
> > <description>Some description</description>
> > <geo:lat>48</geo:lat>
> > <geo:long>2</geo:long>
> > <icons>points.png</icons>
> > </item>
> This type of definitions is a misuse of the RSS format -- adding new
> terms should be done in a seperate namespace. At the moment, there is no
> standardized mechanism for describing visualization of GeoRSS data.
> Rather than making something up and supporting it in OpenLayers, I would
> like to see a general consensus on what is 'acceptable'. Personally, I
> would rather see reuse of the KML specification's visualization
> techniques, which I would be happy to support in OpenLayers. If a
> general consensus is reached -- or even if a specification is created
> and documented, such that future users can look up how to include
> styling/visualization information into their GeoRSS feed by looking at a
> web page -- I would be much more comfortable than with an ad-hoc
> implementation.
> > And copy-paste the part where icon is loaded from the test.js file. Does
> > GeoRSS allow to add its own tag ?
> There is no GeoRSS support for changing the markers built into the core.
> You can change the *default* Marker for OpenLayers, by modifying the
> defaultIcon variable, similar to the code at the end of Marker.js:
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Marker.j
>s#L126
> but I assume you want different icons per-location, which would require
> support in OpenLayers that we do not currently provide.
> I'm CCing this message to the GeoRSS list,
> http://lists.eogeo.org/mailman/listinfo/georss , as discussion on this
> topic is wider than the implementation in OpenLayers: The two issues at
> hand are whether GeoRSS supports multiple channels per file, and whether
> there is a standard definition for describing styling information for a
> feature. If a consensus is reached, I will bring the conversation back
> to the OpenLayers list.
> Regards,
Yves Jacolin
http://yjacolin.gloobe.org
