[OpenLayers-Users] 2.3RC1 - Layer (derived from grid) - Resolution
array being reset to default
gopal krishnan
gopakrishnan at gmail.com
Fri Jan 19 13:18:51 EST 2007
I have a layer taht implements Grid class. With 2.1 it used to work fine.
With 2.3 RC1, it no longer uses the resolution array set inside the layer.
And resolution array gets reset. I understand that some new methods have
been added and initresolutions() method moved.
Has the way to set resolution array changed? if so what is the new way to do
so?
I've copied some bits from the class..
OpenLayers.Layer.MyLayer = OpenLayers.Class.create();
OpenLayers.Layer.MyLayer.prototype =
OpenLayers.Class.inherit( OpenLayers.Layer.Grid, {
DEFAULT_PARAMS: {
* @type Boolean
isBaseLayer: true,
units: "metres",
resolutions: null,
projection: "EPSG:27700",
tileSize: null,
url: null,
type:null,
buffer:1,
initialize: function(name,url, params, options,type) {
this.type = type;
if (this.type == "IMAGE")
this.tileSize = new OpenLayers.Size(250, 250);
this.layer.resolutions = [4096,2048,1024,512,256,128,64,32,16,8,4,2,1,0.5,
0.25];
else
this.type = "MAP" ;
this.resolutions = [4096,2048,1024,512,256,128,64,32,16,8,4,2,1,0.5,0.25];
url = url;
var newArguments = new Array();
newArguments.push(name, url, params, options);
OpenLayers.Layer.Grid.prototype.initialize.apply(this, newArguments);
this.params = (params ? params : {});
if (params) {
OpenLayers.Util.applyDefaults(
this.params,
this.DEFAULT_PARAMS
thanks
G
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070119/3bbfa4b3/attachment.html
