[OpenLayers-Users] overview map - moving rect outside of control
Tim Schaub
noreply at geocartic.com
Mon Jan 22 13:02:22 EST 2007
> I have one more item which I find a bit counter-intuitive in
> the overview map control. When a user tries to move the rect
> to the border of the control, the overview map control throws
> the rect back to its previous position. What I would expect
> is to just drop it at the position where the user has moved
> it to, but don't let him move it outside of the control, so
> drop it at the border.
If your overview map extent is not bigger than the max extent, I think the
extent rectangle is just dropped at the border. When the rect gets thrown
back, I think it is because you are beyond the max extent. There still
could be some funkiness here though.
> Also, is it somehow possible to prevent the overview map
> image from getting selected (the dark blue colour in IE)?
> This sometimes happens when dragging the rect.
I'll address both of these issues with an overhaul in 2.4.
Tim
