[OpenLayers-Users] prevent browser cache
Tim Schaub noreply at geocartic.com
Tue Jan 23 14:13:08 EST 2007
> for dynamically changing data browser cache on images could
> be an unwanted feature. Chameleon for instance always appends
> a random parameter to the url to prevent the browser cache
> from coming into play.
> Is there such a switch in OpenLayers, i.e. to keep urls
> unique? If not, at which level (Map, Layer, WMS, Untiled?)
> would it be appropriate to have such a switch?
This may not suit all, but I think this is best handled at the application
level (i.e. not in the library).  I assume that you have some function that
is triggering the redraw of your layer.  You could trigger the redraw with
something like:
myLayer.mergeNewParams({'TTT': OpenLayers.Util.createUniqueID('ttt')});
Doing it this way (instead of in Untiled.js) gives you a bit more
flexibility in determining when the image should or should not be cached.
Does that work for you?
Tim
> For now I have changed getURL in Untiled.js to get the
> behaviour I wanted:
>     getURL: function(bounds) {
>         var tileSize = this.map.getSize();
>         tileSize.w = tileSize.w * this.ratio;
>         tileSize.h = tileSize.h * this.ratio;
>         return this.getFullRequestString( {'BBOX': bounds.toBBOX(),
>                                                   'WIDTH': tileSize.w,
>                                                   'HEIGHT':
> tileSize.h,
> 'TTT': OpenLayers.Util.createUniqueID('ttt')} );
> Hope to hear some discussion on this subject.
> Best regards,
> Bart
