[OpenLayers-Users] Highlight elements
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jan 25 11:10:24 EST 2007
Christopher,
I believe this is like the mapserver Query functionality. if you do a
query the query results highlighted on the map. In the description
below, the id could be a UID for a shapefile or a database record or
whatever and they want to be able to highlight that object(s) on the
map. This implies some backend process that could select those objects
and render an image that could then be overlaid on the map or some
similar other process.
-Steve W
Christopher Schmidt wrote:
> On Thu, Jan 25, 2007 at 04:45:51PM +0100, Aitor Calero Garcia wrote:
>> Is it possible to highlight elements with OpenLayers? I mean, if I make
>> an alphanumeric query to obtain an id, can I use this id to get the
>> corresponding geographic element highlighted?
> I don't understand the question. Can you give an example webpage that
> does something like what you mean? I don't know what you mean by
> 'geographic element' in this case.
> Regards,
