[OpenLayers-Users] CVS format for OpenLayers.Layer.Text?
Bill Woodall
bwoodall at wardrobe.dhs.org
Wed Jan 31 15:57:37 EST 2007
On Wed, 2007-01-31 at 20:06 +0000, Alexandre Leroux wrote:
> Hi list,
> Wow. OpenLayers is so easy to use. I'm enthusiastic :-)
> Using 2.3-rc2, I have some problems with:
> http://openlayers.org/doc/reference.html#OpenLayers.Layer.Text
> It is said the textfile must be in CSV, but when looking at the example
> textfile.txt, here copied:
> point title description icon
> 10,20 my orange title my orange description
> 2,4 my aqua title my aqua description
> 42,-71 my purple title my purple description<br/>is great.
> http://www.openlayers.org/api/img/zoom-world-mini.png
> This is obviously not comma separated.
> I failed to generate any text file that would be successfully read by
> OpenLayers.Layer.Text. Anyone can reduce the confusion?
> Thanks,
> Alex
Hi Alex,
The docs should refer to the textfile as a Delimiter-separated values
(DSV) instead of Comma-separated values (CSV) and in this case the DSV
are tabs.
The required columns for the textfile are;
point x,y pair in the appropriate units
or
lon the "x" coordinate
lat the "y" coordinate
optional columns are;
title popupContentHTML Title
image,icon url to the "stick pin" image/icon
iconSize yes, the size you want the image/icon to be
iconOffset you guess it, the offset
(for a stickpin use something width/2,-height to position
the image/icon over the point )
description popupContentHTML desc
Hope that helps
.........Bill,
OL/TC user
