[OpenLayers-Users] Problem with WMS.Untiled?
Christopher Schmidt
crschmidt at metacarta.com
Fri Mar 2 11:23:17 EST 2007
On Fri, Mar 02, 2007 at 03:32:21PM +0000, Jon Blower wrote:
> Dear all,
> I've just upgraded to OpenLayers 2.3 (from 2.1) and I've noticed that
> I can't seem to get a WMS.Untiled layer to display - it just comes up
> blank (or perhaps the URL is constructed wrongly). In OL2.1 there was
> a problem with click events on the Untiled layer, but now I can't see
> any Untiled layers.
If you are using MapServer, and your map display is wide, you may be
running into a problem with the image size being larger than the 2048 px
that MapServer will render an image by default. To change the Untiled
layer to *not* double the buffer:
To obtain the behavior of 2.1 in 2.2RC1, you must pass an option of
'ratio': 1
to the WMS Untiled constructor. This was to correct bad behavior on the
part of the Untiled layer, where the slightest, 1 pixel movement would
cause the entire map to reload, a significant user interaction problem.
-- http://trac.openlayers.org/ticket/364
I thought I had better documented this, but apparently I haven't. I'm
sorry for the confusion.
> e.g.:
> var human_wms = new OpenLayers.Layer.WMS.Untiled( "Human Footprint",
> "http://labs.metacarta.com/wms-c/Basic.py?", {layers: 'hfoot' } );
> This works fine as a straight OpenLayers.Layer.WMS.
This is a TileCache Layer. TileCache layers won't work with WMS Untiled.
Christopher Schmidt
MetaCarta
