[OpenLayers-Users] Vector and Vector-2.4 Sandbox
Thomas Zuberbühler
tzuberbuehler at datacomm.ch
Wed Mar 7 10:18:30 EST 2007
Following code should zoom to the USA Population Example from GeoServer. With
Vector Branches there is a too nearby zoom that means there is not anything
visible.
<code>
map.zoomToExtent(new
OpenLayers.Bounds(-124.731422,24.955967,-66.969849,49.371735));
</code>
Could you try this code with Firebug? Do you receive the same result? Thank
you.
Christopher Schmidt-4 wrote:
> On Wed, Mar 07, 2007 at 06:21:48AM -0800, Thomas Zuberb??hler wrote:
>> Dear OpenLayers Developers
>> In this two branches/sandboxes there is a position offset.
>> There is an Example on
>> http://dev.openlayers.org/sandbox/vector-2.4/examples/vector-testing.html.
>> Of course, Barcelona is not in the Mediterranean Sea near Corsica. :)
> Barcelona is not really at
> barcelona = new OpenLayers.Geometry.Point(7,42);
> I'm just lazy :)
> Is there an actual problem, or are you just mentioning that the line is
> drawn to a point which is not actually a city?
>> I tested the Vector sandbox too with a zoom to a bounding box with help
>> of
>> OpenLayers.Bounds. With the official build my function works. Do I assume
>> correctly a bug is present in this branches?
> I'm not sure what position offset you're describing. Can you create a
> small example HTML file that works in the main branch but not in the
> vector branch? There are *no* differences on the Map.js level, so there
> sould be no differences unless you're using a Vector layer.
>> Unfortunetaly I doesn't found some function to add a ticket on OpenLayers
>> Website.
> First login:
> http://trac.openlayers.org/login
> openlayers:openlayers
> Then newticket:
> http://trac.openlayers.org/newticket
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/Vector-and-Vector-2.4-Sandbox-tf3362315.html#a9354804
