[OpenLayers-Users] opacity and wms.notile layer...
John Cole
john.cole at uai.com
Sat Mar 10 11:05:58 EST 2007
Chris,
I've changed my layer def as follows:
var aca_revite_wms = new
OpenLayers.Layer.WMS.Untiled( "PostGIS GDT ACA/Revite Overlay",
"http://kong.uai.int/cgi-bin/mapserv.exe?map=/mapserver/gdt/props.map&",
{layers: 'revite,aca', 'ratio':ratio,
transparent:true,
format:'image/png', visiblity:false, opacity: 0.5});
and it still appears as an opaque layer. Should I have anything special in
my mapfile to make the polygons a transparent layer?
I believe I got the visible:false from one of the example pages, I'll try
and see if that was indeed the case and note it for you.
Thanks,
John
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Friday, March 09, 2007 9:29 PM
To: John Cole
Cc: 'users at openlayers.org'
Subject: Re: [OpenLayers-Users] opacity and wms.notile layer...
On Fri, Mar 09, 2007 at 02:44:40PM -0600, John Cole wrote:
> I've created a wms.notile layer and I'm trying to set it's opacity to 50%
> but it doesn't work for me.
> var revite_wms = new OpenLayers.Layer.WMS.Untiled(
> "Revite Areas",
> "http://kong.uai.int/cgi-bin/mapserv.exe?map=/mapserver/gdt/revite.map&",
> {layers: 'revite', transparent:'true',
> format:'image/png'},
> {'ratio':ratio},{opacity:
> 0.5},{visible:false});
> If I use a tiled wms layer, opacity seems to work fine.
> Any suggestions? (I'm using the current version on FF2).
You want to pass all of your options in a single object.
{ 'ratio': ratio, 'opacity': 0.5, 'visibility': false }
(Note 'visibility', not 'visible'.)
Can you point to the example that lead you to believe you needed to do
something different?
Regards,
Christopher Schmidt
MetaCarta
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.446 / Virus Database: 268.18.8/714 - Release Date: 3/8/2007
10:58 AM
No virus found in this outgoing message.
Version: 7.5.446 / Virus Database: 268.18.8/716 - Release Date: 3/9/2007
6:53 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
