[OpenLayers-Users] pan behaviour for WMS.Untiled
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Mar 20 07:51:09 EDT 2007
Hi Bill,
I am still on 2.3RC2 (I had a problem with 2.3 final which I reported to the
list before).
I tested your code for MouseToolbar and it works fine.
Thanks a lot!
Is this something that could be incorporated into OpenLayers trunk you
think?
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Bill Woodall <bwoodall at wardrobe.dhs.org>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Cc: users at openlayers.org
Onderwerp: Re: [OpenLayers-Users] pan behaviour for WMS.Untiled
Datum: 20/03/07 09:29
> Hi Bart,
> You didn't mention which version (stable, lastest trunk, ...), but
> looking at 2.3 in either MouseDefaults.js or MouseToolbar.js the
> function defaultMouseOut just drops the ball so to speak.
> A modified 2.3 MouseToolbar could look like;
> * @param {Event} evt
> defaultMouseOut: function (evt) {
> if (this.mouseDragStart != null
> && OpenLayers.Util.mouseLeft(evt, this.map.div)) {
> switch (this.mode) {
> case "zoombox":
> this.removeZoomBox();
> if (this.startViaKeyboard) this.leaveMode();
> break;
> case "pan":
> if (this.performedDrag) {
> this.map.setCenter(this.map.center);
> this.mouseDragStart = null;
> this.map.div.style.cursor = "default";
> and the MouseDefaults;
> if (this.mouseDragStart != null &&
> if (this.zoomBox) {
> } else {
> ..........Bill,
> On Tue, 2007-03-20 at 11:02 +0100, Bart van den Eijnden (OSGIS) wrote:
> > Hi list,
> > when somebody drags outside of the map when panning (WMS.Untiled),
part of
> > the map stays white and does not update.
> > In a tiled situation this does not occur.
> > Is this intentional? Does anybody know a quick fix which will cause
the map
> > to update in this case?
> > Thanks in advance.
> > Best regards,
> > Bart
> > http://www.osgis.nl
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
