[OpenLayers-Users] Vector edit example = MouseListener
Christopher Schmidt
crschmidt at metacarta.com
Tue Mar 20 12:40:27 EDT 2007
On Tue, Mar 20, 2007 at 11:09:40AM -0500, Jeff Dege wrote:
> > -----Original Message-----
> > From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> > Sent: Tuesday, March 20, 2007 11:04 AM
> > To: Jeff Dege
> > Cc: users at openlayers.org
> > Subject: Re: [OpenLayers-Users] Vector edit example = MouseListener
> > On Tue, Mar 20, 2007 at 10:53:14AM -0500, Jeff Dege wrote:
> > > I haven't, though, figured out how to use it to edit existing
> polygons.
> > > Moving vertices, deleting vertices, inserting new vertices. Am I
> > > missing something?
> > No. Not all editing tools have not yet been ported to the new
> > framework.
> > I believe Tim was working on them at one point. I don't know
> > if they'll
> > make it into 2.4.
> So if I need to edit, I need to work from examples/select-feature.html,
> rather than examples/editinhgtoolbar.html?
> Not a problem.
select-feature doesn't do editing either... Well, I suppose you could
update geometries and redraw them. Note that the editing toolbar code is
really simple, so you can feel free to extend it to have other things
you might want. The problem is that at the moment there's no drag/drop
ing of points.
I don't know if I'm being helpful or not at this point :)
Regards,
Christopher Schmidt
MetaCarta
