[OpenLayers-Users] Vector edit example = MouseListener
Jeff Dege
jdege at korterra.com
Tue Mar 20 13:02:10 EDT 2007
> -----Original Message-----
> From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sent: Tuesday, March 20, 2007 11:40 AM
> To: Jeff Dege
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Vector edit example = MouseListener
> select-feature doesn't do editing either... Well, I suppose you could
> update geometries and redraw them. Note that the editing
> toolbar code is
> really simple, so you can feel free to extend it to have other things
> you might want. The problem is that at the moment there's no drag/drop
> ing of points.
Select-feature only selects polygons, as it's written now. I'd thought
that maybe by drawing points and polygons simultaneously, I could get it
to select points. But if I can't drag the points I select, there's
little gain.
In an ideal world, the user would be able to drag individual vertices,
delete vertices, insert a new vertex between any two existing vertices.
But for right now, we may just have to give the user the ability to draw
a polygon, and to clear it so he can start over.
