On Fri, Mar 30, 2007 at 11:27:22PM -0600, John Cole wrote: > Thanks, that helped a lot. It's working now. One problem I have noticed is > that the scale control doesn't seem to work... Bet you didn't change your units. :) Set 'units': 'm' or whatever your units are (as an option on the map). Regards, -- Christopher Schmidt MetaCarta
