[OpenLayers-Users] Browser support for 2.4
Glen Stampoultzis
gstamp at gmail.com
Sun May 20 22:38:48 EDT 2007
That's basically the information that I was after - thank you. The vector
thing was particularly important to me as I wanted to be able to plot a
route on a map. Given that SVG isn't supported on Safari I was thinking
that manually creating transparent tiles with the route on them might be the
way to go for Safari. Does this seem like a reasonable approach or can you
use something like the Canvas.js for doing this?
Regards,
Glen
On 18/05/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Fri, May 18, 2007 at 03:15:36PM +1000, Glen Stampoultzis wrote:
> > Hi... just wondering what browsers will be supported for the 2.4release.
> What functionality? The same browser support that we've always
> maintained -- Safari 1.3, Safari 2.0, IE6, IE7, FF2 (and probablay less),
> Opera9 (and probably less) are the ones I run through the tests in when
> I can get my hands on machines with those versions.
> The release notes explain limitations in support for vectors,
> specifically, the latest OS X Safari doesn't support SVG, so it has no
> vectors (download Webkit nightlies if you want them), IE doesn't have
> the XML Serializing tools needed for WFS-T, etc.
> Are you looking for something more specific than that?
> Regards,
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070521/1f7ed14f/attachment.html
