[OpenLayers-Users] label truncation
Gregor Mosheh gregor at hostgis.com
Wed May 23 12:10:49 EDT 2007
Hi, all.
I'm running afoul of one of the more-well-known problems of tiling:
labels are being cut off. What is the recommended method to get around this?
The obvious one seems to be metatiling, in order to reduce the number of
borders; the other is to increase the tile size for the same reason. But
those don't guarantee against a label somewhere being cut off; just a
reduction in its frequency.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
