[OpenLayers-Users] Delaying Layer Initialization
Jeremy Nix Jeremy.Nix at sfsltd.com
Fri May 25 11:35:13 EDT 2007
Is there a way to delay a layer's initialization process? Here's the
situation that we're running into. We have around ten layers that we
want to make available, but the screen's initial loading time is immense
as these layers are mostly tile layers and some servers are better than
others at feeding up the images. We figure that in a given view, the
user is most likely only going to use a handful (2-3) of the given
layers. Maybe a property could be added to a layer to denote whether to
initialize before set to visible. Does anybody else find that to be
useful? Or have you found workarounds of your own to deal with similar
loading time issues?
__________________________________
Jeremy Nix
Senior Application Developer
Southwest Financial Services, Ltd.
(513) 621-6699
Jeremy Nix
(513) 621-6699
