[OpenLayers-Users] Users Digest, Vol 8, Issue 38
Jeff Yutzler jeff.yutzler at ionicenterprise.com
Fri May 25 12:23:04 EDT 2007
Tim,
This workaround works fine at large scale, but unfortunately it
completely breaks down at small scale.  When I try it at 1:433k, 1:216k,
or 1:108k, I get even thicker white lines.  Oh well.  I have Ionic's
RedSpiderWeb team looking at it.
Thanks for trying.
-Jeff
users-request at openlayers.org wrote:
From: Tim Schaub <noreply at geocartic.com> Subject: Re: [OpenLayers-Users]
Vertical lines on WMS layer? To: users at openlayers.org Message-ID:
<4655F1FC.6000909 at geocartic.com> Content-Type: text/plain;
charset=ISO-8859-1; format=flowed Jeff Yutzler wrote:
> > When I set the following WMS layer into OpenLayers:
> >    map.addLayer(new OpenLayers.Layer.WMS( "IONIC Natural Earth WMS",
> > "http://demo.ionicenterprise.com/ionicweb/map/NATURALEARTH", {layers:
> > 'NATURALEARTH'}));
> > I get behavior I have not seen anywhere else.  At most scales, the layer
> > looks fine.  However, at 1:3M and 1:7M, white vertical lines appear at
> > the tile boundaries.  I suppose this is a defect in OpenLayers, but I'm
> > not really even sure how to describe it.  Any ideas?
For tile renderers (WMS servers) that have unsavory edge effects, you
can use the "gutter" option on a layer.  This requests a larger tile
than is actually displayed in OpenLayers - hiding ugly tile edges if you
can't control the tiling yourself (with TileCache).
This functionality was introduced during 2.4 development and will be
included in the 2.4 release.  (See http://trac.openlayers.org/ticket/529
for details.)
In your case, the following layer definition gets rid of the white tile
edges:
   var iconic = new OpenLayers.Layer.WMS("IONIC Natural Earth WMS",
       {layers: 'NATURALEARTH'},
       {gutter: 2});
   map.addLayer(iconic);
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070525/4d909592/jeff.yutzler.vcf
