[OpenLayers-Users] Delaying Layer Initialization
Christopher Schmidt
crschmidt at metacarta.com
Fri May 25 19:35:57 EDT 2007
On Fri, May 25, 2007 at 11:35:13AM -0400, Jeremy Nix wrote:
> Is there a way to delay a layer's initialization process? Here's the
> situation that we're running into. We have around ten layers that we
> want to make available, but the screen's initial loading time is immense
> as these layers are mostly tile layers and some servers are better than
> others at feeding up the images. We figure that in a given view, the
> user is most likely only going to use a handful (2-3) of the given
> layers. Maybe a property could be added to a layer to denote whether to
> initialize before set to visible. Does anybody else find that to be
> useful? Or have you found workarounds of your own to deal with similar
> loading time issues?
Layers shouldn't be loading tiles if they're not visible. If they are,
it's a bug. Example HTML would help debug it. (Visibility is controlled
via setVisibility.)
Regards,
Christopher Schmidt
MetaCarta
