[OpenLayers-Users] Delaying Layer Initialization
Christopher Schmidt crschmidt at metacarta.com
Sat May 26 08:04:52 EDT 2007
On Sat, May 26, 2007 at 10:28:39AM +0200, Arnd Wippermann wrote:
> Hello Christopher,
> I have the same problem (therefor I'm still using Openlayers 1.0).
Okay, thanks. I'd heard reports, but they were always vague in the
problems they were reporting.
> OpenLayers should only load tiles for the baselayer from gis.ibbeck.de and
> wms.jpl.nasa.gov for the world image. If you use firebug, you could see,
> that the tiles for the other servers are also loaded.
Agreed. I'll file this as a bug against 2.5. Since it's been around since
the start of the 2.0 branch, it's not enough to delay 2.4.
> After the first load of the map, pan and zoom loads only the tiles for the
> visible servers.
> http://gis.ibbeck.de/ginfo/ibbOLClient/OLC2.3%20RC1.html?MAPNR=10000&LAYERS=
> 11200,12700,11500,11500,10600,10700,10900,11000,10000&ZOOM=3&CENTER=10.1745,
> 50.819
> (If I load the newest version from
> http://svn.openlayers.org/branches/openlayers/2.4/, Revision 3188 says the
> html-page and my svn-program, the OpenLayers.VERSION_NUMBER is still
> "$Revision: 2942 $". Miss I something or is this a bug).
This is expected -- the VERSION_NUMBER is relevant to the last time that
file was updated. Part of the release process is to edit the
OpenLayers.js file (to change the license), so releases get a new
VERSION_NUMBER -- it's only useful on releases. Unfortunately, I don't
know of a better way to automate this.
> Is it possible with the number of the revision also deliver a variable with
> the plain text for the OpenLayers Version(example: 2.4 RC4).
There is no automatic way of doing this, and it's a step that I fear
would be missed if we made it a human intervention step, which is why
it's not done. If you're actually using RC4 -- that is, from the /tags/
instead of the branch -- the VERSION_NUMBER represents that.
Regards,
Christopher Schmidt
MetaCarta
