[OpenLayers-Users] editingtoolbar position in custom application
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Mon Nov 5 04:03:34 EST 2007
i tried to implement the editingtoolbar-outside example into my application.
Basically it worked to put the toolbar outside my map but the toolbar is
displayed on the top right of my html page. How/Where can i change that? I
expected that the position is managed by the style section with
.olControlEditingToolbar, but changes there have no effect!
here is my html code for the toolbar:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<link rel="stylesheet"
href="/usr/share/openlayers-2.5/theme/default/style.css" type="text/css" />
<style type="text/css">
.olControlEditingToolbar {
float:left;
right: 0px;
height: 30px;
width: 150px;
#map {
width: 800px;
height: 500px;
border: 0px solid black;
position: absolute;
top: 40;
right: 25%;
<!-- float:center; -->
#layerswitcher {
width: 25%;
height: 60%;
</style>
<script src="http://172.21.18.45/openlayers/lib/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init(){
var options = { scales: [800000, 600000, 250000, 125000, 75000, 30000,
10000],
'projection':'EPSG:31258', 'units':'m',
'maxExtent': new OpenLayers.Bounds(390730, 119473, 594760, 238680),
'maxResolution': "auto",
controls: [new OpenLayers.Control.MouseDefaults()],
layers: [l_wms],
minRatio: 8,
maxRatio: 128
map = new OpenLayers.Map($('map'),options, { controls: [] });
map.addControl(new OpenLayers.Control.PanZoomBar());
map.addControl(new OpenLayers.Control.MouseToolbar());
//map.addControl(new OpenLayers.Control.MousePosition());
//map.addControl(new OpenLayers.Control.OverviewMap());
map.addControl(new OpenLayers.Control.Scale());
map.addControl(new
OpenLayers.Control.LayerSwitcher({'div':OpenLayers.Util.getElement('layerswitcher'),
activeColor:"red"}));
map.addControl(new OpenLayers.Control.OverviewMap(options));
//--------------- EditToolbar ---------------
// vlayer = new OpenLayers.Layer.Vector( "Custom Layer");
// map.addControl(new OpenLayers.Control.EditingToolbar(vlayer));
vlayer = new OpenLayers.Layer.Vector( "Editable" );
var container = document.getElementById("panel");
var panel = new OpenLayers.Control.EditingToolbar(
vlayer, {div: container}
map.addControl(panel);
//END ------- Edit Toolaber --------------
// ------------------------------------------------------------ Layer
// ---------------------------------- WMS
var g_wms = new .....
var l_wms = new .....
var b_wms = new .....
var lg_wms = new .....
var l_st_wms = new .....
//--------------- Define Layers -------------
map.addLayers([l_wms, b_wms, g_wms, lg_wms, l_st_wms, vlayer]);
//map.addControl(new OpenLayers.Control.LayerSwitcher());
//LayerSwitcher Panel
map.zoomToMaxExtent();
</script>
</head>
<body onload="init()"; style="color: rgb(0, 0, 0); background-color:
rgb(0, 0, 0);">
<!-- <h1>Orthophotos</h1> -->
<div id="layerswitcher" style="float:center;"></div>
<div style="margin-left: 20%;" id="map"; ></div>
<div id="panel" class="olControlEditingToolbar"></div>
</body>
</html>
I have a simmilar problem with the layerswitcher outside the map, it is also
displayed on the right of my application but the layerswitcher change the
position when I make changes in the style section (but the background of the
layer allways remain on the right side of the html page)
View this message in context: http://www.nabble.com/editingtoolbar-position-in-custom-application-tf4750311.html#a13583238
