[OpenLayers-Users] drag zoom control images
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Tue Nov 6 09:02:30 EST 2007
I´ve exactly the same problem. When i move the slider with the mouse, the
slider stick to my cursor. When i move away from the slider and then go back
with the mouse the slider is still pending on the mousecursor and moves also
out of range.
don´t know how to fix that
Eric Jarvies wrote:
> brad,
> i went to http://mumbai.freemap.in/ , a site that also uses the zoom
> bar(the standard issue openlayers zoom bar), and i attempted to
> replicate the errors. when holding down the mouse and moving the
> slider up and down the bar, after a few passes, the slider indeed
> leaves the outer limits of the bar. upon release of the mouse, the
> slider will return to it's last position prior to clicking it.
> whereas on your site/example, if the indicator has moved outside of
> the bar area, either top or bottom, and the mouse is released, it
> will stay outside, and if the mouse is not clicked, it will continue
> moving, even if switching to another browser window, or another
> application all together. upon returning to your map, the slider is
> still moving with the mouse, and the only way to make it return to
> the zoom bar is to mouse down again inside of the zoom bar area, and
> to move the mouse in the respective up or down direction to make the
> indicator move inside the bar area, or to simply click on the zoom
> bar, in which case the indicator returns to that position, then
> immediately jumps a few positions up or down. so i think the bulk of
> the problem has to do with your you've structured your images within
> your <div> tags. also, the openlayers default zoom bar is shorter
> then is the one you created. perhaps you should also double check
> your px; values, to make sure everything corresponds.
> once you make the above-mentioned fix, that will address the slider
> problem not returning to the zoom bar, as well as the slider jumping
> to another position on the zoom bar, and then your zoom bar/slider
> will be on par with the default zoom bar/slider.
> but the underlying issue/bug will still remain, meaning, the slider
> is still leaving the zoom bar area when moused-down-and-holding-and-
> moving. clearly, this error only occurs when the person
> intentionally mouses down and moves up or down out of range of the
> bar, so it is intentional by the user, thus it will not occur that
> often. but, i would be remiss not to at least make mention of it, so
> that it can be corrected, as it seems like an easy fix. should i
> file a ticket for this? or is someone with capacity/repository
> access listening?
> default openlayers zoom bar and slider:
> <div id="OpenLayers_Control_PanZoomBar_Zoombarundefined"
> style="background-image: url(http://openlayers.org/api/2.2/img/
> zoombar.png); left: 13px; top: 81px; width: 18px; height: 121px;
> position: absolute;"/>
> <div id="OpenLayers_Control_PanZoomBar_Sliderundefined"
> style="position: absolute; left: 12px; top: 170px; width: 20px;
> height: 9px;">
> http://
openlayers.org/api/2.2/img/slider.png
> your zoom bar and slider:
> <div id="OpenLayers_Control_PanZoomBar_ZoombarOpenLayers.Map_2"
> style="background-image: url(http://demo.cubewerx.com.au/openlayers/
> OpenLayers-2.5/img/zoombar.png); left: 13px; top: 81px; width: 18px;
> height: 176px; position: absolute;"/>
> <div id="OpenLayers_Control_PanZoomBar_SliderOpenLayers.Map_2"
> style="position: absolute; left: 12px; top: 203px; width: 20px;
> height: 9px;">
> http://
demo.cubewerx.com.au/openlayers/OpenLayers-2.5/img/slider.png
> regards,
> eric
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/drag-zoom-control-images-tf4741350.html#a13607226
