[OpenLayers-Users] OverviewMap Container
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Thu Nov 8 05:44:21 EST 2007
Great, Thank Your Richard that worked perfectly
I added the {theme: null} into both options and it worked!
Richard Duivenvoorde wrote:
> The Openlayers css is included programmically and overriding your css:
> see: Map.js or Openlayers.js:
> // only add a new node if one with an equivalent url hasn't already
> // been added
> if(addNode) {
> var cssNode = document.createElement('link');
> cssNode.setAttribute('rel', 'stylesheet');
> cssNode.setAttribute('type', 'text/css');
> cssNode.setAttribute('href', this.theme);
> document.getElementsByTagName('head')[0].appendChild(cssNode);
> So try as told here:
> http://www.openlayers.org/dev/examples/custom-style.html
> >> cut
> If you care to modify the style of any OpenLayers element, include the
> default stylesheet as a link and declare any style modifications below
> that link. These style declarations can be in other linked stylesheets
> or in style tags. In addition, construct your map with options that
> include {theme: null}. This will disable the default method of loading
> the stylesheet and allow you to declare style rules in your own linked
> stylesheets or style tags.
> << end cut
> R. Ortner wrote:
>> hi,
>> no, i only use my own stylesheet, here is the beginning of my html file:
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <link rel="stylesheet"
>> href="/usr/share/openlayers-2.5/OpenLayers-2.5/theme/geoland_theme/geoland_style.css"
>> type="text/css" />
>> <style type="text/css">
>> .olControlOverviewMapElement
>> background-color: green;
>> .olControlOverviewMapExtentRectangle
>> border: 2px dotted black;
>> </style>
>> <script
>> src="http://172.21.18.45/openlayers/lib/OpenLayers.js"></script>
>> <script type="text/javascript">
>> var map;
>> function init(){
>> var options = { scales: [800000, 600000, 250000, 125000, 75000,
>> 30000,
>> 10000],
>> 'projection':'EPSG:31258', 'units':'m',
>> 'maxExtent': new OpenLayers.Bounds(390730, 119473, 594760, 238680),
>> 'maxResolution': "auto",
>> controls: [new OpenLayers.Control.MouseDefaults()], //
>> Weltkugelsymbol
>> (Zoom to max extend) unter dem Zoomregler entfernt
>> // options 2 --> optionen für die OverviewMap
>> var options2 = {projection: "EPSG:31258",
>> units: 'm',
>> maxExtent: new OpenLayers.Bounds(390730, 119473, 594760, 238680),
>> format: 'jpeg',
>> transparent:"false"
>> // layers: [lg_wms]
>> // Baselayer wird automatisch geladen
>> map = new OpenLayers.Map(('map'),options, { controls: [] });
>> what scripts are liable for overwriting the container color?
>>> Hi Reinhard,
>>> looks like the styles from you stylesheet are overridden by script?
>>> Did you include the default stylesheet as a link and declare any style
>>> modifications below that link?
>>> Like shown/mentioned here:
>>> R. Ortner wrote:
>>>> Hi,
>>>> i put the Overviewmap outside my map with the <div option...
>>>> now i tried to change the color of the container by changing it in the
>>>> style.css .olControlOverviewMapElemet Section but no effect.
>>>> I made a new custom styleX.css, but it in the html file in the
>>>> stylesheet
>>>> section, but still no effect so far the container color is blue!
>>>> then i tried to but this:
>>>> .olControlOverviewMapElement {
>>>> to the style section of my html file;
>>>> What happens is that when i load the map, very short before the
>>>> overview
>>>> is
>>>> loaded the color is green and then it is overwritten by the standard
>>>> blue
>>>> color!
>>>> does anyone know why?
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://www.nabble.com/OverviewMap-Container-tf4770009.html#a13644775
