[OpenLayers-Users] OverviewMap Container
R. Ortner
reinhard.ortner at edu.fh-kaernten.ac.at
Thu Nov 8 06:39:50 EST 2007
Just one more thing,... after adding the theme:null to my options, the
editingtoolbar which i put outside the maps with:
vlayer = new OpenLayers.Layer.Vector( "Editable" );
var container = document.getElementById("panel");
var panel = new OpenLayers.Control.EditingToolbar(
vlayer, {div: container}
map.addControl(panel);
<div id="panel" class="olControlEditingToolbar"
style="position:absolute;left:1055px;top:300px;width:35px;height:130px;background:white;z-index:30"></div>
is gone!
I see the white background but the buttons are disappeared!?!
any idea why?
R. Ortner wrote:
> Great, Thank Your Richard that worked perfectly
> I added the {theme: null} into both options and it worked!
> Richard Duivenvoorde wrote:
>> The Openlayers css is included programmically and overriding your css:
>> see: Map.js or Openlayers.js:
>> // only add a new node if one with an equivalent url hasn't already
>> // been added
>> if(addNode) {
>> var cssNode = document.createElement('link');
>> cssNode.setAttribute('rel', 'stylesheet');
>> cssNode.setAttribute('type', 'text/css');
>> cssNode.setAttribute('href', this.theme);
>> document.getElementsByTagName('head')[0].appendChild(cssNode);
>> So try as told here:
>> http://www.openlayers.org/dev/examples/custom-style.html
>> >> cut
>> If you care to modify the style of any OpenLayers element, include the
>> default stylesheet as a link and declare any style modifications below
>> that link. These style declarations can be in other linked stylesheets
>> or in style tags. In addition, construct your map with options that
>> include {theme: null}. This will disable the default method of loading
>> the stylesheet and allow you to declare style rules in your own linked
>> stylesheets or style tags.
>> << end cut
>> R. Ortner wrote:
>>> hi,
>>> no, i only use my own stylesheet, here is the beginning of my html file:
>>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
>>> <html xmlns="http://www.w3.org/1999/xhtml">
>>> <head>
>>> <link rel="stylesheet"
>>> href="/usr/share/openlayers-2.5/OpenLayers-2.5/theme/geoland_theme/geoland_style.css"
>>> type="text/css" />
>>> <style type="text/css">
>>> .olControlOverviewMapElement
>>> background-color: green;
>>> .olControlOverviewMapExtentRectangle
>>> border: 2px dotted black;
>>> </style>
>>> <script
>>> src="http://172.21.18.45/openlayers/lib/OpenLayers.js"></script>
>>> <script type="text/javascript">
>>> var map;
>>> function init(){
>>> var options = { scales: [800000, 600000, 250000, 125000, 75000,
>>> 30000,
>>> 10000],
>>> 'projection':'EPSG:31258', 'units':'m',
>>> 'maxExtent': new OpenLayers.Bounds(390730, 119473, 594760, 238680),
>>> 'maxResolution': "auto",
>>> controls: [new OpenLayers.Control.MouseDefaults()], //
>>> Weltkugelsymbol
>>> (Zoom to max extend) unter dem Zoomregler entfernt
>>> // options 2 --> optionen für die OverviewMap
>>> var options2 = {projection: "EPSG:31258",
>>> units: 'm',
>>> maxExtent: new OpenLayers.Bounds(390730, 119473, 594760, 238680),
>>> format: 'jpeg',
>>> transparent:"false"
>>> // layers: [lg_wms]
>>> // Baselayer wird automatisch geladen
>>> map = new OpenLayers.Map(('map'),options, { controls: [] });
>>> what scripts are liable for overwriting the container color?
>>>> Hi Reinhard,
>>>> looks like the styles from you stylesheet are overridden by script?
>>>> Did you include the default stylesheet as a link and declare any style
>>>> modifications below that link?
>>>> Like shown/mentioned here:
>>>> R. Ortner wrote:
>>>>> Hi,
>>>>> i put the Overviewmap outside my map with the <div option...
>>>>> now i tried to change the color of the container by changing it in the
>>>>> style.css .olControlOverviewMapElemet Section but no effect.
>>>>> I made a new custom styleX.css, but it in the html file in the
>>>>> stylesheet
>>>>> section, but still no effect so far the container color is blue!
>>>>> then i tried to but this:
>>>>> .olControlOverviewMapElement {
>>>>> to the style section of my html file;
>>>>> What happens is that when i load the map, very short before the
>>>>> overview
>>>>> is
>>>>> loaded the color is green and then it is overwritten by the standard
>>>>> blue
>>>>> color!
>>>>> does anyone know why?
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
View this message in context: http://www.nabble.com/OverviewMap-Container-tf4770009.html#a13645469
